200 ms UDP Read timeout causes error ( but works in UDP Receiver.vi)
@jlivermore wrote:
You asked if the UDP send/receive are running on the same computer? How can I do that..run them on the same computer? That would save check-out time. TIA.
Simply open both the receiver and sender on the same computer. The instructions on the front panel of the UDP Receiver example VI tell you to do exactly that.
Message 11 of 12
(606 Views)
Thanks again, MERC. Appreciate your responses. Smiley Happy
-jesse
Message 12 of 12
(591 Views)
