2010 print report not working
I just recently upgraded from Labview 8.6 to Labview 2010. The print function report was working without any problems after execution build. In the latest version, 2010, the execution builds without any errors. The build is installed using the installer and no errors are reported. The print function no longer works.
I searched the list and found an article on report generation toolkit for MS Office. Am I required to NIReport.lib and LVclass?
(3,109 Views)
Joseph:
Does the VI work in the 2010 development environment (before you build it into an executable)?
Also, what article did you find on the Report Generation Toolkit? I might be able to provide better assistance if I can take a look at the article.
Thanks!
Caleb Harris
National Instruments | http://www.ni.com/support
(3,080 Views)
It works fine in the devlopment enviroment. When you build an executable, it does not work, even though I ran it on the development computer. I just added the 2 directories in and at least one of the application works. I am now testing the main program but I have to wait until something starts operating.
The title of the article is:
Error 7 When Running an Application using VIs from Report Generation Toolkit for MS Office"
(3,074 Views)
I rebuilt the program with the report lib and class. The program is now printing properly again. I noticed during the conversion process, some of my shortcuts disappeared.
(3,041 Views)
Hi Joseph
Can you explain what you mean by your shortcuts are gone? is this a html report?
Joe Daily
may the G be with you ....
(3,024 Views)
