2020 Interfaces and Multiple Inheritance
I understand the utility of and differences between the classes and interfaces and the solution to the diamond problem by disallowing dynamic VIs of the same name between 2+ interfaces inherited by a class.
But does anyone know what was the reasoning behind allowing multiple inheritance from Interfaces but not regular classes in LV2020?  Was this a technical constraint underneath due to potentially multiple sets of class data or more of a design decision to enforce certain best practices, or some combination?
I saw my father do some work on a car once as a kid and I asked him "How did you know how to do that?" He responded "I didn't, I had to figure it out."
(4,571 Views)
Accepted by topic author blackburnite
You might want to just give this a good read: LabVIEW Interfaces: The Decisions Behind the Design
I have barely been able to skim it, but there is a whole section on the Call Parent Method that will kind of answer your question.
(4,545 Views)
