2020 Visual Bug? Single Input Compound Arithmetic Not Allowed With Error?
I don't fully understand what triggers this condition.  But I've seen times when the Compound Arithmetic node with one input, and the error data type showing a broken wire, but the VI can be ran.
The VI does actually run, but the wire shows it is broken.  Attached is the code saved in LabVIEW 2020 that reproduces the error.
Message 1 of 9
(6,811 Views)
Single input Compound Arithmetic seems crazy to me (but I see why you did it).  I'm not surprised that it's buggy.
I would just replace it with an unbundler.
Message 2 of 9
(6,805 Views)
I often use single input Compound Arithmetic to perform inversion - either numeric (1/x) or boolean NOT.   It's more compact than the native functions so it fits between wires when I place it inline between subvi's that use all 4 standard outputs and inputs (a.k.a. gazottas and gazintas).
No insight on the visual bug, I've never had it happen.
-Kevin P
Message 3 of 9
(6,794 Views)
Yeah I hope the demo VIs shows why you might want a feature like this, even though it seems an odd choice at first.  There are probably a dozen other ways to accomplish something similar, but this seemed logical to me.  Yes the unbundle would work just fine, but it is a bit smaller on the BD and I couldn't see a reason why it shouldn't work.
Also it probably shouldn't surprise anyone, but the old band-aid of Always Copy fixes this graphical issue.
Message 4 of 9
(6,778 Views)
For we Newbie's, can you please explain what "Always Copy" means?  I don't think I've (probably because I'm not quite as inventive) the problem you're describing, but I also occasionally "squeeze" functions in between wires, so might want to avail myself of these nifty ideas, but don't know where to find the band-aids ...
Bob Schor
Message 5 of 9
(6,741 Views)
Bob Schor
Check the Application Control >> Memory Control Palette
Always Copy will make a data copy of what is contained on the wire.
mcduff
Message 6 of 9
(6,701 Views)
Yeah I was keeping a list of times the Always Copy fixed a weird bug, or edge case.  But after a while I realized keeping a list of the primary feature of a function seemed silly.
https://forums.ni.com/t5/LabVIEW/TDMS-Write-cannot-accept-datatype-what-s-going-on-here-then/m-p/293...
Message 7 of 9
(6,652 Views)
Can someone from NI confirm this bug?  Assign a CAR?
Message 8 of 9
(6,591 Views)
I've created Bug 1518595 to track this issue.
Christina Rogers
Principal Product Owner, LabVIEW R&D
Message 9 of 9
(5,789 Views)
