24-bit sound
Is it possible to play 24-bit sound with LabView using SO config SO write
etc.?
TM
(2,972 Views)
TM,
Not at this time. We only support 8-bit and 16-bit sound at this time with that VI. You may be able to write your own by going directly through the Windows API (Waveform Functions)
Randy Hoskin
http://www.ni.com/ask
(2,972 Views)
Of course I'm not sure what device you're talking about...
But I looked into this one of these Soundblaster 5.1 cards as a possible
cheap 24-bit alternative to the NI cards. When I called the creative labs
developer support group and pressed them for information, they claimed that
the card in question actually was normal 16-bit I/O and the 24-bit
advertised on the box was only in some internal sections of the card.
So in the end Labview only supported the 16-bit modes, but the soundcard
specs were kind of deceptive anyway and I couldn't have done 24-bit
acquisition. Double check with the developer support line for your hardware
so you're not on a wild goose chase like I was.
-joey
"TM" wrote in message news:3e2eb7db@newsgroups....
> Is i
> etc.?
> TM
(2,972 Views)
