24 hour timer error with Get Date/Time In Seconds Function
Hi Folks,
I made a simple timer vi that logs a four channel DAQ NI9215 using the "Get Date/Time In Seconds Function" and one of the examples provided by NI.  I'm testing a timer that turns a motor on then off and then after 24-hours turns it on and off again.   I was surprised to find that my 24-hour timer was off by 7min.  I'm guessing my timer is off by 7min but I just wanted to check with the forums and see if anyone else has seen the windows/network time out by this much over a 24-hour period.
-SS
(3,070 Views)
Hello ShotSimon,
I looked into the Knowledge Base and I didn't found anything on it regarding this problem.
Try to see if the problem occurs with other scenarios.
Mr.O
(3,029 Views)
