 rootsjames
			rootsjames
			01-12-2010 10:29 AM
I just downloaded the Eurotherm ET24xx driver from NI driver page.
When I run the sample VI's the Vi's are missing loads of sub VI's eg "read from register floating point.vi"
Can anyone help me with this? is the driver missing sub vi's or is there something I should do??
James
Solved! Go to Solution.
 RavensFan
			RavensFan
		01-12-2010
		11:15 AM
 - last edited on
		03-14-2024
		09:14 AM
 by
		 Content Cleaner
			Content Cleaner
That sounds like a VI that would be part of the Modbus library.
 d_n
			d_n
			01-13-2010 05:12 AM
Hi James
The driver is not missing any vis. Unzip the files and read the et24xx Readme.html
You need to extract the files and install them as per instructions in the et24xx Readme.html file Section 3.
There are two libraries ( et24xx.llb and _et24xx.llb). The first contains the main vis and the other the Low level vis.
If you are asked for sub vis point to _et24xx.llb, but if you follow the installation instructions we will have no problems.
Dimitris
01-13-2010 10:31 AM
That worked Dimitris!!
Cheers
