24V TO 5 V conversion
Hi.
My DAQ module 9401 has a digital counter input on it which it is a TTL 5V high/low signal. I am attempting to use it to count the pulses that an encoder puts out. The issue is that the encoder puts out 24 volt pulses, not the 5V that my DAQ can read. I was looking for some suggestions for solutions, whether it be through a few resistors or some more complicated circuitry.
Message 1 of 15
(12,847 Views)
You can buy complete level shifting boards, no need to fiddle with resistors yourself. For instance this one: https://www.sparkfun.com/products/12009
 Or buy a chip: https://nl.farnell.com/c/semiconductors-ics/logic/level-shifters
Message 2 of 15
(12,843 Views)
Hi sobansair,
the 9401 has a ±30V overvoltage protection built in, so you could (at own risk!) use it with 24V pulses too.
But I prefer some resistors and Z diodes for protection…
Message 3 of 15
(12,824 Views)
2 resistors that'll work as voltage divider should be easy enough. E.g. 1k + 4,2k, connect the DAQ over the 1k resistor.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 4 of 15
(12,814 Views)
That one is not made for handling 24V.  And finding level shifting chips that can handle 24V is also really hard (I have yet to run into one).
The simple solution is a resistor and Zenor diode circuit.  For more isolation, a solid-state relay would be a good way to go.
Message 5 of 15
(12,796 Views)
Ah, didn't look at the specs enough. But an optocoupler is also a good option. For instance this one: https://www.amazon.com/24V-Optocoupler-Voltage-Level-Converter/dp/B06XKSFGXX
You do have to check if the speed is fast enough. An encoder signal can be quite fast.  There is also a 80 kHz variant.
Message 6 of 15
(12,791 Views)
Well if a simple voltage divider will not work why not just use a transistor and a couple resistors like this?
You might have to change the resistor values in the voltage dividerYou might have to change the resistor values in the voltage divider
=== Engineer Ambiguously ===
Message 7 of 15
(12,764 Views)
I like the idea of optoisolators particularly if there is a concern of galvanic isolation.
If R1 is blown you will have 24V on the base of the resistor.
Ben
Message 8 of 15
(12,748 Views)
Ben
Why would R1 blow?
Even if if did all that would probably do is blow the transistor and put constant 5 volts on the output.
Nothing too tragic. Well except for shorting the 24V to ground through the shorted transistor...
Message 9 of 15
(12,737 Views)
More likely, it would "short" 24 volts to the 5 volts supply and the 5 volts input of the following electronics, which is quite dangerous for those electronics. The ground line has still another resistor in it. So that optocoupler in not a bad idea at all. But I agree that there is normally little worry for a 10K resistor (in this configuration) to blow up.
Message 10 of 15
(11,835 Views)
