2635A Trigger from BUS
Hello, I want to trigger the keithley 2635A by other instruments such as keithley 6430 from the GPIB interface.
Attached is my code, I use the advanced trigger VI from the driver to set the outsite stimulus.
According to the trigger model, only after 2635A receiving the trigger from the BUS(*TRG) it can finish a S-D-M cycle.
However, I found that for my code, without *TRG from BUS, 2635A also finish the measurement.
Is anybody could give me some help on this?
Thank you very much!
Adwards
Message 1 of 1
(2,336 Views)
