28 segment display with decimal point
OK another question. So far i get 4 of the same number. How can i get 9 to be 0009 while looping it?
Message 11 of 27
(2,101 Views)
Please post what you have tried so far.  Guessing at what you might have done or not is not very productive.
Lynn
Message 12 of 27
(2,096 Views)
Your right i'm just trying to wrap my mind around this I'll also upload the file if you would like
Message 13 of 27
(2,092 Views)
You are just sending the same data to all 4 indicators.
Try this.
Message 14 of 27
(2,065 Views)
Here is my version.  I created a lookup table of clusters of booleans, the same as your display clusters and avoided the conversions.  Also I have shown one way to get the digits from a number >9.
Lynn
Message 15 of 27
(2,061 Views)
Ok wow thanks! Do you know how i could impliment a decimal point?
Message 16 of 27
(2,057 Views)
If the decimal point is always in the same location, such as xxx.x, then multiply the numeric value by ten and convert the result to an integer.  This gives a 4-digit integer which can easily be handled by the method I posted.  The display only sees the digits and does not know where the decimal point is.
Lynn
Message 17 of 27
(2,036 Views)
You could do a log base 10 of the number (assuming it is a double).  Take integer value of that (floor) and add 1.  That will tell you how many digits are to the left of the decimal point.  Then you could "Turn On"  the decimal point in the respective cluster.
Message 18 of 27
(2,032 Views)
Thanks to everyone you guys have been a great help!
Message 19 of 27
(2,021 Views)
Hi im not sure if anyone is still watching this thread but i have tried your ideas about the decimal point and i feel dumb for saying but i'm not sure exactly how to use your methods.
Message 20 of 27
(1,988 Views)
