2D Array Append
Hi All,
I've spent way too long trying to figure this out already, anyone know of a good way to accomplish this (see attached pic)?
Adam
(7,856 Views)
Sorry, its late on a Friday, got it.  Maybe this will help someone 🙂
(7,853 Views)
Here's a solution where you don't need to worry about the dimensions as long as both arrays have the same number of rows. Note that the "built array" is in concatenate mode)
(If they have different number of rows, the shorter wins)
Message Edited by altenbach on 11-14-2008 03:00 PM
(7,848 Views)
This isn't really a better solution, but just so you're aware of array operations you can also use Transpose Array:
Message Edited by smercurio_fc on 11-14-2008 05:15 PM
(7,840 Views)
