2D Array question
I have built a 2D array of strings, which is sorted alphabetically by column 0. Column 0 will be headings, and column 1 is the data. I want to search the array by row 0 to n-1, column 0 and blank out the duplicate items, while leaving all of the data in column 2.
(2,950 Views)
Hi Daveton,
If I understand you correctly, after your sort, duplicates entries should consecutive. So...
Try split of the first element in a collumn and use it to init a shift register. Compare each element with the previous. If equal, replace with empty string. If not keep the new value and update your shift register.
I hope this helps,
Ben
(2,950 Views)
