2D Array to String Conversion
Hi, I am having some trouble converting my 2D array into string data. I tried casting but 2D arrays seem incompatible with String data.
The attached is how I currently do this with 1D arrays and it works well. Any ideas for doing the same with a 2D array would be appreciated. Is there a quick way to do this without having to take a subset of my array?
Message Edited by russelldav on 05-12-2008 03:03 PM
Message 1 of 12
(21,302 Views)
You can reshape a 2D array into a 1D array. Look at the Reshape Array function on the Array palette.
Lynn
Message 2 of 12
(21,296 Views)
Have you tried the following?
Cheers
Message Edited by jmcbee on 05-12-2008 02:08 PM
Message 3 of 12
(21,295 Views)
Thanks guys!
I reshaped it and it works perfectly! Thanks so much.
<sarcasm>
P.S Next time can you be a bit quicker with your responses? I almost had to wait a minute before I had the answer I needed Smiley Very Happy
</sarcasm>
Message Edited by russelldav on 05-12-2008 03:20 PM
Message 4 of 12
(21,290 Views)
Hi
I am having a similar problem, i have to read the dat from excel (for ex,it has some 40 rows and 3 coulmns) and need to convert it to string.
I tried as in the attached figure, in the dimension size of the reshape array what value i need to enter (either the coulmn or row)
Message 5 of 12
(21,175 Views)
Hi Veeru,
you can simply select "string" instead of "double". It is a polymorphic vi. Smiley Wink
And after that you can use the "Concatenate String" function or you read it as a "normal" textfile.
Hope it helps.
Mike
Message Edited by MikeS81 on 06-11-2008 01:02 PM
Message 6 of 12
(21,168 Views)
Thanks Mike
What ihave to do if i need to read only the 2nd column value(40*3 Array)
Message 7 of 12
(21,160 Views)
Hi Veeru,
use the "index array" function, use then number to string.
Mike
Message 8 of 12
(21,156 Views)
Thanks Mike
Message 9 of 12
(21,154 Views)
this is so bad
Message 10 of 12
(7,874 Views)
