2D array from 1D
Hi there,
This is a very rookie question but I am having a bit trouble figuring it out.
I have a 1D array
E.g. 1 2 3 4
And I want to convert it into 2D array with known number of rows and columns.
E.g. 1 1 1 1 1
2 2 2 2 2
3 3 3 3 3
4 4 4 4 4
I am not sure if it has been answered before, I looked through a few related questions. I couldn't find anything.
Thank you.
(3,777 Views)
Accepted by topic author kumar1993
I would just use a FOR loop.
(3,729 Views)
It is unclear exactly what you want to do, but read up on the simple array functions, there is no special tricks involved.
Something like this perhaps, it will give the output you specified.
(3,719 Views)
I figured out. Thank you for the replies. I used "replace array"inside a "for loop" and then "tranpose array".
It worked.
Thank you again.
(3,709 Views)
