2D array into excel
Thank you guys, it's now working more or less!!!
Message 11 of 14
(3,065 Views)
all the best..Cat Happy
Message 12 of 14
(3,059 Views)
Hi guys,
I have another problem now: The .txt-file I use is very big (2 columns, around 30k rows), and it takes over a minute to run the program. As I said, I don't really understand how the labview example file I use works, but it seems to write one row after another into excel. Is it possible to speed up the process by changing the VI somehow?
Thank you!
Message 13 of 14
(3,049 Views)
ActiveX is known to be "not the fastest". That being said (without trying myself): It should be possible to write a range of cells at a time. So you probably can spare the inner or both for loops and write the whole array into one range of cells.
Norbert
Norbert
Expert: Geometry
Message 14 of 14
(3,035 Views)
