2D array search
I had 2D array, this array column 1 represent year. Column 2 represent profit.
How to use for loop to search input year then find profit
ex: input    2012
      output  0.4
Message 1 of 10
(3,623 Views)
Hi Aaron,
convert the 2D array of 2 columns into an array of points, then use the Interpolate1DArray function!
(No FOR loop needed.)
Message 2 of 10
(3,603 Views)
tks a lots interesting method
bcz i had three clusters need searching
two input(Stock number, year) get one output(profit)
now I'm stuck with how to use while loop to get output
Message 3 of 10
(3,572 Views)
Hi Aaron,
  • Why did your requirement changed from 1st to 2nd post?
  • Why is the "Stock number" input a float when the value in the cluster is an integer?
  • Why do you ask for a WHILE loop when your image only shows a FOR loop?
  • Why do you show just images of code instead of attaching REAL code? (We cannot debug/edit/run images with LabVIEW.)
  1. At first a loop will select the correct cluster, based on the stock number.
  2. Then you can apply my previous suggestion on the 2D array inside the cluster…
Message 4 of 10
(3,566 Views)
wanna searching like
when input1(stock number):2819, input2(year): 2010, then get output(profit):0.64
never searching for cluster so I'm stuck in this issue now
Message 5 of 10
(3,558 Views)
Hi Aaron,
you still don't provide an example VI.
I still cannot edit/debug/run images with LabVIEW (see my previous message) and I don't want to recreate your array of clusters "manually"…
(Take care of my signature line.)
I can also provide images of code:
Message 6 of 10
(3,537 Views)
this my code tks your patient for wait me asking question
first time suffering cluster, so can't figure out
Message 7 of 10
(3,529 Views)
when stock:8299
           year:2018
still can't recieve my ideal profit(output):2.988
please help me to debu thanks a lot
Message 8 of 10
(3,509 Views)
Accepted by topic author ironaaron
Hi Aaron,
@ironaaron wrote:
when stock:8299
           year:2018
Because you don't read the LabVIEW help for the used functions!
Please read the help for Interpolate1DArray, it mentions an important requirement for the arrangement of your data! (See the "Note!" at the end of the help article.)
Then re-arrange your data to fit this requirement…
Message 9 of 10
(3,503 Views)
ignore this crucial note, sincerely my fault
Thank you for patiently answering my questions.
Message 10 of 10
(3,497 Views)
