2D array to Tensity graph,How to hide the picture when no data arrive, and show with new data come?
    I have a  U16 2D array,which will  change value every 1 send ,  I know how to draw  intensity graph, but I do not want the graph show all the time except when new data coming, I mean the graph always hides, and popup when new data is coming. How can I achieve this?And I am using Labview 2011.
   Hope for your help!
  Thank you!
(2,715 Views)
Did you try the Visible property of the graph? Any time you can turn ON/OFF depending on the data.
(2,711 Views)
I have tried, but the major difficity is how to achieve "popup"?
(2,707 Views)
If you want a pop-up, then create a seperate VI with just the graph and update the data to it (using Global variable/Functional Global). You can keep the window as floating, so whenever the data comes you can pop-up the window inside that VI.
(2,698 Views)
