2D array to cluster of 2 elements
In my program I use a cluster of two 1D-array : X array, and Y array. (cluster of 2 elements).
I want to create spreadsheets with X and Y values (in 2 rows) and import it from .xls to labview, to use in my cluster.
The problem is that the VI "Read from spreadsheet file.vi" give me a 2D-array, where I would like two 1D-array to put it in my cluster.
Do you know how to convert this, or another way to get what I want ?
Thanks in advance !
J.D.
French Labview beginner
N'oubliez pas de complimenter les bonnes réponses - Don't forget Kudos for good answers
(3,777 Views)
Ok I was unable to use Index Array, but now it's ok..
Sorry for wasting your time reading 🙂
J.D.
(3,775 Views)
Arg, still not OK. It looks like the function is designed to read ROWS.
And I need to read COLUMNS (i was wrong in my first message).
Does anyone know how to do please ?
J.D.
(3,755 Views)
Jim
(3,742 Views)
Also, when wiring a 2D array into Index Array, there are two inputs: row index or column index. Thus, you could just wire a value into the column index to peel off a column. Please review the documentation on Index Array.
(3,717 Views)
