2D array to webVI using SystemLink
Hi all,
I have a 2D array in my .gvi that I want to write in a .gviweb using SystemLink tags. The user of the webVI should be able to adjust the counting time (second column) and  therefore I cannot use a string. It doesn't seem like SystemLink supports arrays. What could be an alternative? array.PNG
(3,037 Views)
Hi RoboNuC4,
The Generate Tag Cluster can be used to create an array of tag clusters. This can then be wired to the Multi Write Node to record the values in a single operation.
Furthermore, the array values can be read in a single operation using the Multi Read Node.
Ellin A.
Technical Support Engineer.
(2,953 Views)
Thank you for your reply, but it does not seem to be possible to wire array to this node either. Could perhaps make an example, please?
(2,950 Views)
