2D array with formula node
hi,
i was looking on this forum and found this picture:
that 2D array input would help me so much in my VI but i can't find it anywhere in labview(newb lol), i need an 2D array where i can preset the value's because i'm going to use the 2D array for a filter and i need to add the value's myself, how is best way to do this? and could this be done in C code only or is it easier to use a labview function?
any tips are alwasy welcome 🙂
Grtz
(8,050 Views)
Are you asking how to make the constant?  Drop down an array constant.  Right-click on it and select Add Dimension.  Put a numeric constant in the array container.  Done.
(8,046 Views)
Hi stin,
when you don't know how to create a BD constant you surely should attend the LabVIEW beginners courses offered by NI!
And when you ask for preferring LabVIEW- or C-style code in a LabVIEW forum you should expect the answer "LabVIEW functions of course!"...
(8,040 Views)
If you already have a function that expects an array (e.g. index array), right-click the input and "create constant". This probably gives you a 1D array, so simply resize the array index so two elements show to make it 2D. Expand the size of the container to show the desired number of array elements. Enter your values.
(8,022 Views)
