2D data into x,y.z points
I have 2D data array (64×64) and trying to convert the data into x (-31 to 31),y (-31 to 31) ,z (0-255). I'm not sure how to do this. Please advice.
Thank you.
(3,690 Views)
Hi Ledang,
Can you be more specific about your doubt?
Best Regards,
Dhans 😉
Kudos are welcome 😉
Aspirant Labview Programmer (Labview 14) 😉
(3,675 Views)
He doesn't have a doubt.  He has a question.
It would be helpful if some actual data was attached.
I'm going to assume that the indices of the 2-D array are what is to be translated into the X and Y values.  Now you said you have a 64 x 64 array.  But X and Y from -31 to 31 is only 63 elements in each.
What I would do is create a nested For Loop.  Autoindex on the 2-D array at each boundary.  Use the i value of the For Loops and subtract 32.  In the inner For Loop you can bundle the inner loop's i value, the outer loop's i value, and the value of the array into a cluster of XYZ.  Take that cluster and auto-index on the output tunnels and you'll have an array of XYZ clusters.  (On the outer loop, you can make it a concatenating tunnel so it becomes a 1-D array of all the 1-D arrays coming from the inner loop.)
(3,618 Views)
Accepted by topic author Ledang
Here's another simple solution. Modify as needed depending on how x and y are defined.
(3,607 Views)
Thanks for the reply. I tried and come out with this VI and it's works!.
Ledang
(3,546 Views)
Thanks, it really helps.
Ledang
(3,543 Views)
