2D data to Excel
I have a 2D array of numerical data that I need to save as an Excel file... How to do ?
(4,548 Views)
If you have report generation tool kit you can use it for reading and writing into Excel. If you don't have it, then you can use Activex methods to do it. Check the attached VI. You will get a good understanding of doing it.
Nitz
(Give Kudos to Good Answers, Mark it as a Solution if your problem is Solved:smileywink:)
(4,544 Views)
I do have report generation toolkit ... I don't know how to use it because I've never used it... 😞
How should I give the path where I want to save the excel file?
(4,537 Views)
Do you really want the Excel file or you can have a .xls file that you can view using MS Excel?. If you just need a file you have to view using excel then its very simple.
(4,527 Views)
I really don't need an excel file 🙂 ... viewing through Excel is enough 🙂
(4,520 Views)
Accepted by topic author Shweta_Sridhar
Then you can do like this. I guess this should be sufficient
Good luck.
(4,514 Views)
Ya thanks... I found that the mistake which had been causing me a problem 🙂 🙂 ... Thanks a ton 🙂
(4,511 Views)
