2D picture control doesn't refresh if it is out of the active screen
In my application I have used a 2D picture control to display Process illustration in picture based GUI. Based on user events I update the illustration, like when a user turns on a pump, then I replace the grey colored pump picture clip with green color pump picture clip on the illustration. I have to do this some times when Illustration is not visible on the screen(for example user turns on the pump in some other settings window). Then if I come back to the illustration screen, the illustration is not updated(I still see the grey color pump picture though pump is turned on in the Settings screen). In this scenario, I have probed the Illustration.Value input wire and the probe value is green color pump clip is passed to the picture control with proper coordinates.
I see this issue when illustration is out of the active screen. If illustration screen is active and visible then I don't see this issue.
I have referred this discussion and tried out the suggestions, but did not help.
I am using LabVIEW 2021 64bit on Windows 10.
Has some one experienced this? Please write your suggestions here.
Thank you
Adarsh
LabVIEW from 2006
CLA from 2016
(726 Views)
Your attached picture does not illustrate the problem. Can you attach a small set of VIs that reproduces the problem so we can test?
(669 Views)
