2D picture control rotating text
Hello All,
I need to develop a number of avionics styled instruments for the user interface part of my program. I decided to do this using the 2D picture control and have had some success developing the compass lines. See attached image
I then moved onto trying generate the numbers and letters and rotate them around the compass, this is where I have been getting problems
First I found I cannot get the [user specified font] parameters to work in the Draw Text in Rect.vi to work. For example the font size doesnt appear to work for me.
Next I tried to find a way to print text at varying angles around the compass on the pic control, the only method I could find was convert the text to an image and rotate it around the compass centre by looping my code with new text on each iteration. Unfortunately as I rotate the string the text dissappears behind the white pane and and black rectangle appears in place of the shifted box.
I would like to continue using the picture control as it suits the number and type of instruments I need to construct. Otherwise I will need to modify the Labview dials and indicators. Is there a Picture Control toolkit available I have seen yet or an old post solving these issues?
Help Appreciated
Chris
(3,165 Views)
User specified font works.  See attached VI.
For rotate test, pad the text with spaces before and after sting before converting to a picture.
Look for an Add-In for LabVIEW using Package Manager or check NI's site.
You are off to a good start!
Matthew Fitzsimons
Certified LabVIEW Architect
LabVIEW 6.1 ... 2013, LVOOP, GOOP, TestStand, DAQ, and Vison
(3,113 Views)
