2D projection of contour plot
Hello
I know there are a lot of threads around about contour plotting, but everyone seems to want 3D graphs, I just want a 2D projection of one, with the z values represented by level curves in the xy plane.
I have been using the attached example to create something similar to what I want: I set "plot type" to cwSurfaceContour and make both "XY projection" and "Show projections only" true.
The result is exactly what I am looking for except that I want the z axis gone. Just a normal 2D plot.
Thanks in advance,
Steve
(5,675 Views)
If you have LV 2011, look in the Mathematics/Computational Geometry palette - there is a new VI called Contour Line which will do what you want.  There is also an example which shows how to use it.
(5,671 Views)
Hmmm... I only have 2009. Guess it's time to update.
(5,669 Views)
There is a contour control in LV2009, though it is a 3D one. You can mimic a 2D contour by clicking the XY button on the projection palette.
If you want to gain better performance since 2D is enough for you, try Contour Line.vi in LV2011.
(5,658 Views)
