2D slice from 3D
I have a 3D array [200][150][15]
How can I slice a 2D array from this to
display via IMAQ?
(3,119 Views)
Accepted by topic author csk
Index Array with the first index set to the page you want to "slice out". The output is a 2D array.
To learn more about LabVIEW it is recommended that you go through the tutorial(s) and look over the material in the NI Developer Zone's Learning Center which provides links to other materials and other tutorials. You can also take the online courses for free.
(3,113 Views)
