2D to 3D array
@altenbach wrote:
The 3D array will automatically pad to the largest 2D array subset once you autoindex at the output tunnel.
Here's what I had in mind.
Message 11 of 14
(1,530 Views)
I want to be able to get the split points from the data rather my telling the VI that the split points are 3 and 5.
I hope that makes sense.
Message 12 of 14
(1,518 Views)
What in the data tells you where to split?
CLA
https://www.prevas.se/expertis/test--regulatoriska-krav.html
Message 13 of 14
(1,508 Views)
The value in the first cell of each row.
I ended up using your suggestion of find split points in the 2D array but finding those split points programmatically.
Message 14 of 14
(1,496 Views)
