2D to 3D plot
I have a chunk of code that plots points representing 3D vectors, some of which are connected with lines. The data for each point arrives in dozens of 3x1 arrays within a cluster (I just replaced them all with a constant in this attached file), and I switch between different views using the ring and array index values.
What is the easiest way to replace all of this with a single 3D plot?
(3,648 Views)
Hello Graham,
I have built you a VI that takes the data as described in your forum post and plots it on a 3D graph. The project and VI’s I have created are in 2010 SP1, let me know if you require a previous version.
Regards
Andrew George @ NI UK
(3,619 Views)
That's great Andy, thank you. I am using LV 2009.
(3,615 Views)
Hi Graham,
Here you go mate!
Regards
(3,612 Views)
Hi Andy,
I can see what you've done and it makes sense .. but I'm receiving data in real-time. So would be unable to use the for loop to re-package the arrays. I should have said that before! The attached is the plotting part of my 'offline' version (where I play with mathscript), it has some data which gives a better idea of what I'm trying to achieve. I'll have a go at modifying your code ..
Graham
(3,606 Views)
Hi Graham,
I have changed the program so it updates during run time. Have a look an let me know what you think.
Regards
(3,575 Views)
