2d Array Problem
Sorry for asking you sir, actually in my first VI based on the array size the case strucutre is executing ,within the case structure i'm doing all that conversion right ,so now in the solution which you have given we are not checking out the array size, so i'm confused.
Message 11 of 12
(469 Views)
Thank you sir , i understood what you said it worked, Thanks a lot for you patience in solving this..
Message 12 of 12
(454 Views)
