2d Array name to item names issues
    i am working on this small code where I want to select a sensor which will output 3 axis. but I set the list box of the sensor selection to 1 or more selection mode. So when I pick more than one sensor I get 6 axis (3 for each sensor) in my indicator array. My problem is I want to list those axes in a list box. but the list box for the axis is 1D array and the item names property node is 1D array as well. My problem is the reference array for the sensor axes are 2D array. How do I get them to list?
 Please help..... An image of the short code is provided
Admin Note - Attachment removed per user's request
(3,846 Views)
Accepted by topic author ritch_by_nature
Use Reshape Array to change your 2D array into a 1D array.
(3,826 Views)
Thanks. I decided to use a multicolum lisbox instead so I can have all the three axes of my sensor showing when i select more than one sensor. But I am not able to select item on the second or third column of the multicolum lisbox. Is there a reason why? I trying playing with the properties but nothing works
(3,749 Views)
Hi ritch,
in a (multicolumn) listbox you can only select rows!
To get a better visual impression you may select the property "mark full row" in the listbox properties…
(3,734 Views)
