2d Gaussian Fit Problem.
Sorry, I don't have IMAQ. Could you replace your image with a diagram constant of a 2D array?
Also, since your data is arranged in a grid, all you need is reshape to a 1D array (the picture array and the function output inside the model), you don't need this advanced coding that also works for scattered xyz data.
Message 11 of 24
(8,688 Views)
Here is an old example for this. (read the entire thread to fit for an elliptic peak of arbitrary rotation, see image below)
Message 12 of 24
(8,686 Views)
Dear
I replaced the same image with static 2d array. thanks for your time
cheers
 xg
Message 13 of 24
(8,679 Views)
As I said, you should use code that is optmized for gridded data. There is no reason to do the xyz dance.
Here's a quick rewrite of my older code.
(simply read your PNG file, wat a few seconds, and it will fit it just fine. For faster fitting, you should take a reasonably sized subset around the peak)
Message 14 of 24
(8,668 Views)
And here's how it would look taking a reasonable subset. Much faster! (same model VI as above)
Message 15 of 24
(8,666 Views)
Dear
Many thanks for your quick reply and help. I thought of using the subset too.
I will need a newer version to read your code. ( my one is 2012 ).
very appreciated your time.
xg
Message 16 of 24
(8,654 Views)
Here's the LabVIEW 2012 version.
(EDIT: rezipped and uploaded new version)
Message 17 of 24
(8,644 Views)
Many thanks
again, thanks for your help.
xg
Message 18 of 24
(8,634 Views)
I am having trouble extracting your zip file.  It seems corrupt.  Could you please re-upload a new version?
Message 19 of 24
(8,598 Views)
This thread contains 6 zip files. can you tell which one is giving you problems?
Message 20 of 24
(8,589 Views)
