2d array to 1d waveform, optimization?
Greetings to all
I have a vi that accomplishes the task of converting a 2d array dbl  to a 1d waveform  (and concattenating that with another waveform)  However, it is the most memory and time intensive task, and i'm sure there is a better way to accomplish it.
VI attached
I wish I had asked this at the webinar on memory this week 😞
-Regards
eximo
_______________________________________________
UofL Bioengineering M.S.
Neuronetrix
"I had rather be right than be president" -Henry Clay
(3,287 Views)
Define "memory intensive" and "time intensive". You also said you are using the VI to concatenate the data to another waveform. The VI is doing no such thing. It overwrites the Y array element for each waveform in the waveform array.
(3,275 Views)
whoops, duh, nevermind.     well...........thanks!   that actually changes things, i'll repost it once i fix that
-Regards
eximo
Neuronetrix
(3,273 Views)
