2d array to cluster
thank you i finally got it!
Message 11 of 15
(4,280 Views)
Just for fun, here's what I probably would have done. It is arguably less code than what you did above. 😄
See if you understand any of it 😉
Message 12 of 15
(4,263 Views)
@altenbach wrote:
<snip>
Anyway, you code is way too complicated and a solution could probably fit on a postage stamp. To count the number of TRUEs in a boolean array of any dimension, you would simly use "boolean to (0,1)" on the array directly followed by "add array elements". No loops needed. Try it!
<snip>
OMG - I never thought of that.  Thanks for the tip!
Bill
CLD
(Mid-Level minion.)
Message 13 of 15
(4,222 Views)
Sir thanks for the elaboration !
But i couldn't solve the problem. Still, i am in same mess. VI is attached. Also the file in which error is coming, is attached. I believe we can't do any change in ml_Distance_L2 Norm.vi , as that is stored in program files-machine learning. So where am i doing wrong in my VI (query.vi).
Please suggest something.
Thanks & best regards !!!
Message 14 of 15
(3,993 Views)
Sorry
posted at wrong place....
Message 15 of 15
(3,989 Views)
