2d array with multiple graphs
I would like to read in a spreadsheet of data in columns and be able to select which column the graph displays. I have (hopefully) attached what I have so far as a couple of images and the xls file. Any ideas?
(3,826 Views)
Dear slipstick
you just need to transpose the input data as shown in figuers.
(3,813 Views)
that worked!
Thanks!
Tay
(3,772 Views)
The transpose works but you need to understand something more basic about the index array function. You wired a control to the 'row' input. If you want to extract a column, you need to wire your control to the 'column' input. The transpose is an unnecessary operation.
(3,755 Views)
