2d array
Hello !
What is the best way to put data into 2d array ?
I have colunm numbers (data channels) and the data for them.
So I want a table where each channel is on its own colunm.
(3,421 Views)
Make an array with each your column data. Append these arrays. You have now a 2d array with your channel data arranged in rows. Now transpose this 2d array.
A kind of magic.
See attachment written with LabVIEW 6.
(3,421 Views)
Use "Insert Into Array" or "Build Array"
See attached example.
(3,421 Views)
