2d arrays
How do I use a for loop to generate a sine wave with an amplitude of 10 and a DC content of 3. then send the a output to waveform chart and an array then find the peak and DC value, the size of the output array by computation?
(3,827 Views)
How do I get people to do my homework for me?
(3,823 Views)
Thanks for your help Jason
(3,810 Views)
Your question is laughibly easy to implement with a basic understanding of labview.  Also the framing of the question suggests a poor solution.  You do not need a for loop to create a sine wave.  Labview has built in trig functions.  Why reinvent the wheel?
Message Edited by jasonhill on 07-07-2006 08:44 AM
(3,806 Views)
Thanks again Jason Im new to Labview just having a little problem with the concepts
(3,791 Views)
(With appolgies to devchander)
'Life does not get easier that LabVIEW'
Read these links to learn LabVIEW
Three Hour Introduction to LabVIEW
Six Hour Introduction to LabVIEW
The part you want is about halfway through the second presentation, but I highly recommend viewing ALL of it.
Labview's documentation is very complete and high quality.  You will be amazed at the things you can learn by reading them.
Hope this helps
=j
(3,783 Views)
