2d to 1d array conversion
having problems with 2d array conversion to 1d array.  for example there is a 2d array with the first row having 2 values of 5 and 7.
the next row has values 4, 6, and 8. looking like this
A    B
C    D     E
my problem is that when i try and convert to a 1d array using reshape array function, the output has an "empty" array value between the B and the C.  looking like this
A    B   "empty"  C   D    E
is there a way to eliminate the empty array and concatenate the strings to look like A   B   C   D   E.
Thank you
(3,592 Views)
I think this is what you're looking for.
(3,578 Views)
The array control will automagically resize the array if any row has more elements than any previous row.  So your array was really:
A B _
C D E
Where "_" is an empty string.  To remove the empty strings, you could use something like this:
I susspect that there is a clever way to do it with array to spreadsheet string and back, but I am not sure exactly how that would work.
Message Edited by jasonhill on 08-11-2006 04:23 PM
(3,572 Views)
Thank you very much for the help.  the first solution works and i will try the second as well
(3,564 Views)
