2nd 'For' loop not counting correctly
Hi. Can anyone help with this problem please. I have two 'For' loops running sequentially. The first loop loops 4 times correctly then onto the second loop. The second loop refuses to loop more than 4 times. Any number 1 to 4 in the contol constant works fine, but any number greater than 4 will not work. i.e The second loop loops 4 times then continues out of the loop. There is nothing within the loop to account for this.
regards.
(3,475 Views)
maybe you can post your VI...
Labview CLD , Engineer/Manager
Promedes and DSM
using LV 7.1, 8.0, 8.2, 8.5 and 2009 SP1
http://www.promedes.nl
(3,469 Views)
It's impossible to answer your question without some more information.
Please attach a jpeg of your diagram to show us what you mean.
Shane
Using LV 6.1 and 8.2.1 on W2k (SP4) and WXP (SP2)
(3,466 Views)
Hi Ian,
e.g. you create an array consisting of 4 Elements in the 1st for-loop and wire it onto the 2nd loop, then the connection point will be automatically set to "Activated Indication". To stop this, you have to make a right-click on this connection point and select "Deactivate Indication". Doing this you can set the loop-counter to a higher number as are elements in your array.
Please take a short look at the attached vi.
 Andi
~~~ Logic is a systematic method of coming to the wrong conclusion with confidence ~~~
(3,460 Views)
Problem sorted!.Thanks Andi.
Regards. Ian
(3,444 Views)
