Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
2pi constant in formula node
nancy 520
Member
03-09-2002
08:48 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
How do you use the 2pi constant inside a formula node? pi(2) and 2*pi do not work. Using labview 6i.
0
Kudos
Message
1
of 3
(11,430 Views)
Reply
Re: 2pi constant in formula node
Lab Viewer
Active Participant
03-09-2002
11:13 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Find attached VI for a version that is working (y=2*pi;). Maybe something else is wrong inside your formula node.
Anyway, you can wire PI as an input for that formula node and use it as a variable.
Hope this helps
0
Kudos
Message
2
of 3
(11,430 Views)
Reply
Lab Viewer
Active Participant
03-09-2002
11:14 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Sorry, I forgot to attach the VI.
2xPI.vi 7 KB
0
Kudos
Message
3
of 3
(11,430 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
