3 Phase AC Power Meter/Transducer Drivers
We need to buy some AC digital panel meters with digital output.  We can't use just a Transducer and PLC, as we need the digital meter function at the measurement point.  We want to use RS232 or 485 output from a meter as input to labview
  We are measuring each phase and total of 600 VAC, 3000KW, PF, HP, AAC off a VFD, so we need a meter built for it.
So far, we have found meters but none that labview lists drivers for:  Units manufactured by:
- Satec (PM line)
- Crompton (integra line of )
- Acuvim (Acuvim Line)
I assume there are other manufacturers (Ge, Siemens??) that may have power meters as well.  We don't care which manufacturer, just want to make it simple on ourselve by already having a labview driver for it.
Message 1 of 12
(5,299 Views)
We have also found these:
- Yokogawa PR300 series meter has 485 output...
- GE EPM series meters
Message 2 of 12
(5,292 Views)
We have also found this meter series:
- siemens pac series.
Message 3 of 12
(5,274 Views)
Have used the Yokogawa  Digital Switchboard 2490 Power Plus series w/485 for many years.  That series may not do HP but one of the other Yokogawa series should work just as well.
Message 4 of 12
(5,263 Views)
Thanks for info... Do you have a Labview driver for it??
Message 5 of 12
(5,258 Views)
Did you search the Instrument Driver Network? In any case, I have used the WT1600 from Yokogawa for voltaBges up to 1000V and .5MW and the drivers from NI. Used a GPIB connection.
Message 6 of 12
(5,249 Views)
Thanks.. The WT line from yokogowa are great oscilliscopes.. but they cost about $20/e
We are looking for drivers for the panel meters which are only about $700/e
Thanks for you input.. any ideas on panel meters drivers??
Message 7 of 12
(5,243 Views)
What does "/e" mean?  Does it mean "per each"?  That isn't a normal abbreviation.
If something is $20, isn't that a better price than something that is "only $700"?
Message 8 of 12
(5,232 Views)
Sorry type (I meant to type $20k... /e is an abbriviation for each..
Message 9 of 12
(5,219 Views)
Test Stand Man,
So how many individual panel meters are you looking at total?    It sounds like you will be buying several.
Message 10 of 12
(5,201 Views)
