3 conditions
You have a potential race condition where you are reading a local variable containing the value for average and also setting it to a random number without enforcing dataflow.  If your previous run had an average value lower than .161, the compare on the following (incorrect) run could execute prior to updating of the average value indicator and thus cause the problem you're seeing.
Message 11 of 14
(1,256 Views)
Accepted by topic author jmejiagusmer
jmejiagusmer wrote:  In this particular case, I am getting a boolean true when my exit temp 1 is 0.161412 and my average is 0.173414. I have no idea why this would give me a true when it's clearly false?? Since I know that the boolean is returning true when it should be returning false, this doesn't even have anything to do with the select functions. This appears like it would be a problem with either the greater than function or the boolean array? I am very confused with this result.
That is the classic race condition issue with local variables.  Your comparisons are likely being done with the data from the previous iteration.  USE DATA FLOW!  Use wires instead of local variables.
I took the liberty of cleaning up your VI and got rid of the loop (not needed here anyways).  You should aim for something along these lines.
Message 12 of 14
(1,239 Views)
just an example to show the 3 conditions....
Message 13 of 14
(1,229 Views)
Thank you! I just did the same thing to my VI and it works perfectly now!
Message 14 of 14
(1,205 Views)
