3-d array to xlsx file (excel) - help needed
Hi guys,
i've a question for you...
i would save an excel file (.xlsx) having as input my 3-d array...i would that first dimension are my excel worksheets and then the other 2 dimensions are the data inside each worksheet.
I know that there is the report generation toolkit, and i would use it....but i don't know in which way 🙂
could you help me?
Many thanks and nice holidays!
PS: i use labview 2009
(3,327 Views)
Curious... what holidays?
Go here and click the Download button.
It's pretty easy to use and the VIs are very straightforward. You probably want the Excel Specific VIs Excel Easy Table and Excel Add Worksheet.
Report back after you've played around with the toolkit a bit.
As far as the 3D array goes, you're going to want the first subarray to be the worksheets (it will actually be a 1D array of worksheet names, right?), so you would index your array twice to get a 1D array of strings.
Next to get each set of data, you're going to get the Index 1 value from the array and so on. Index 1 will be a 2D array data for the first worksheet, Index 2 will be the next 2D array and so on.
Cheers
(3,299 Views)
