3-d surface graphs in Linux LV 8.6
I need to draw a surface graph from data where the z axis can take one of 14 values and the (x,y) coordinates range from 0 to 1, with no fixed intervals.  In essence, I have 14 horizontal slices of a surface, with 50 random surface observations on every slice.  How can I display this as a surface using LV 8.6?
Earl
(3,808 Views)
Hi Earl,
Unfortunately, the 3D graph object in LabVIEW uses ActiveX, which I'm sure you know only works with Windows. However, there some work arounds that others have posted in these other threads:
http://forums.ni.com/ni/board/message?board.id=170&requireLogin=False&thread.id=186413
http://forums.ni.com/ni/board/message?board.id=170&message.id=259968&requireLogin=False
http://forums.ni.com/ni/board/message?board.id=170&message.id=84789&requireLogin=False
(3,788 Views)
Doesn't 8.6 have native 3D graphics for Linux?  I just don't know if what I'm finding will do what I need.
http://zone.ni.com/devzone/cda/tut/p/id/7337#toc2
earl
(3,783 Views)
Hi earl,
You're right, as of LabVIEW 8.6, 3D graphics are supported on Linux. To do a surface plot you will need to use the Surface Plot VI found on the front panel. You will find the control under Modern » Graph. You will then need to wire in x, y and z values in an array format. The x and y values are both 1-D arrays and the z values are in a 2-D array.
The order of the elements in the arrays matter. The first element in the x and y arrays and the element at (0,0) of the z array is one point on the surface plot. The first element in the x array, the second element in the y array and the element at (0,1) of the z array is the another point on the surface.
(3,767 Views)
I can set my data up that way, but it will be a sparse matrix:  My observations don't fit a grid.  Can the plotting algorithm handle a sparse matrix?
(3,758 Views)
In what form are you representing the sparse matrix? You will have to convert it to a 2-D array (which I realize is essentially a matrix but LabVIEW does differentiate between the two) before you wire it to the Surface Plot VI.
(3,729 Views)
