3 level PWM inverter
Things are coming along. Now im on SIT. Could u pls tell me how can I change the parameters of a "three phase voltage source" from Simulink in SIT. I have tried my best linking up the ports but still unable to change anything properly (e.g frequency,amplitude, etc )
Thanks.
Message 11 of 18
(4,461 Views)
Message 12 of 18
(4,450 Views)
Hi Deborah,
One more thing. When i try to contruct a dll file from my simulink , it gives me this error (Attached picture).
I ran mex-setup and tried everything i could. I think it has some problem with the VC++ compiler. Kindly advise.
Thanks.
AAK.
Message 13 of 18
(4,446 Views)
Deb is out of the office for a day or so, but I thought I'd chime in. I had a similar issue a while back and it had to do with me selecting the wrong C++ compiler. Which one did you select?
Kevin H. | Applications Engineer
Message 14 of 18
(4,401 Views)
Hi , i tried all of those optons given in the attached pictures. None of  these working. What did u select when u faced this error ??Kindly help me out.
AAK
Message 15 of 18
(4,394 Views)
My apologies for the delay in reply. So firstly I'd ask that you copy all the text in there (including everything from when you started the application) and attach the text file, just in case! You can download new compiler version from microsoft. Once you've confirmed all your versions, we'll discuss some other options!
Kevin Horecka | AENIC
Message 16 of 18
(4,369 Views)
Hi Kevin,
I have installed VC++ 2010 edition. but don't know how to link it up with my MATLAB. its still giving me the same old compiler options which i had in previous messages.
HELP!!
AAK.
Message 17 of 18
(4,353 Views)
I haven't had that problem myself, but I was googling around to see why they might not show up. I'm assuming you've done the basics like restarted your computer, restarted matlab, etc. Given all this, those compilers should be in a directory like C:\Program Files\Microsoft Visual Studio 10.0
If you don't see something like that on your machine, something may have gone wrong with the install. I found this suggestion regarding 2008 on the matlab forums.
Are you on a 64bit machine? I've seen some weird things happen with 64bit, but nothing specific comes to mind. Make sure what you downloaded was on this list of supported compilers.
Kevin
Message 18 of 18
(4,339 Views)
