32-Bit LabVIEW RT 2019 finds a 64-Bit .so on NI Linux RT, but doesn't find the 32-Bit .so
I have a .so library, both a 64/32 bit version.  These are located at /usr/lib on a PXI running 64-bit NI Linux RT.
When calling a function from this library, the deployment fails, if the call library function node is configured to use the 32-bit library, with error that it was unable to find the library.  It does not fail with the 64-bit version.
This does not make sense to me since LabVIEW RT is 32-bit.
I saw my father do some work on a car once as a kid and I asked him "How did you know how to do that?" He responded "I didn't, I had to figure it out."
(2,732 Views)
Only if your RT target uses an ARM CPU. If it is an Intel CPU it absolutely certainly is a 64 bit executable (but you don't notice it from your Windows system as LabVIEW transparently cross compiles it for the 64 bit Linux target).
Rolf Kalbermatter  My Blog
(2,693 Views)
This is what I thought was happening based on the behavior but I couldn't find any documentation going into detail on the RT engine for NI Linux as far as bitness and/or how compilation occurs from 32bit-LabVIEW.
(2,661 Views)
