32 bit faster than 64 bit
I take performance benchmarks from NI with a good-sized grain of salt. I won't tell you why in this forum, but let's just say BTDT.
Message 11 of 15
(1,085 Views)
From NI only? Smiley Surprised
Benchmarks are like statistics. Don't trust them if you haven't forged them yourself! Smiley LOL
And performance increase numbers in marketing text are usually a single number from an engineer, taken out of context and declared as general fact. Just like many of the "technical" articles in non-technical publications like newspapers and popular media.
Rolf Kalbermatter  My Blog
Message 12 of 15
(1,057 Views)
I don't even trust my own benchmarks. 😄
Message 13 of 15
(1,034 Views)
I thought the 64 bit version would be more CPU effecient than the 32 bit version.
NI seems to acknowledge that its 64-bit implementation was not done for more efficiency.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000kIctSAE
LabVIEW 32-Bit and 64-Bit Compatibility, Updated Jul 30, 2023, "LabVIEW 64-bit does not provide any speed improvements over LabVIEW 32-bit"
Message 14 of 15
(591 Views)
The CPU specific compiler is purely LLVM dependent. The NI optimizations are in the data flow graph to DFIR transformations and they are on a level where the CPU is not yet relevant.
Also, 64-bit is typically larger due to all pointers and even offsets being generally double the size. Memory bandwidth is a real concern even with high speed DDR5 memory and also causes caches to fill up faster so can result in more cache misses. That easily can kill simple and not so simple gains in 64-bit code execution.
But NI is not really involved in the LLVM development at all, other than using it. So it is what it is!
Those 64-bit gains of 20 to 25% are based on carefully crafted code that makes maximum use of the new optimized CPU instructions and tuned to fit into local CPU cache in order to reduce memory bandwidth effects.
Message 15 of 15
(585 Views)
