32 bits data format with SDW library
I carried out a SPI communication with the SDW library with a 16 bits data format. This is working perfectly. However, I have to improve my labview code in order to manage a 32 bit data communication. Unfortunatly, the library seems to not work this format. In fact, when I change my data (16 bits to 32 bits), my clock is changed by the library but it's configured for a 64 bits data format.
Does someone have the same problem ? Is there a problem in the SDW library for the 32 bit data format ?
I attach a picture of my problem, it could help you to answer to my issue.
Thank you for your answers,
GL
Message 1 of 1
(3,234 Views)
