33220A invert output
hello all, i want to invert one 10ms negative pulse by software trigger, but i can't find any output invert driver. Anyone can help me? i am using version labview 8.6.
(2,837 Views)
This seems to be an issue with not knowing how to use the instrument and not how to do it in LabVIEW.  If you read the manual, you should be able to figure it out how to do it.
My suggestion is to learn how to do everything you need to do manually before you try to do it programmatically.
Bill
CLD
(Mid-Level minion.)
(2,826 Views)
