34970A Initialization reproduction
I am trying to reproduce Figure. 3 from http://zone.ni.com/devzone/cda/tut/p/id/4644
My problem:
After creating the Serial Port Cluster (Timeout, baud rate, flow control) and attempting to connect it to the approriate connection on the HP34970 initialize block I get a message that says: "You have two or more enumeration data types wired together, but the enumerations are different. The list of items in the enumerations must be exactly the same."
I believe my issue is with the Flow Control enumeration input, the last one in the Serial Port Configuration cluster in Fig. 3.  I double checked the properties of all the cluster inputs and compared them to the example, they matched.  But did not work.  However when I dragged the Flow control input from the example and dropped it into my cluster, the connection was made with no errors.  I don't understand what the difference between the example Flow Control input and my Flow Control input is.
 What am I doing wrong?
or perhaps an easier question, what is step-by-step the correct method of creating the Serial Control Cluster?
(2,958 Views)
Accepted by topic author Oreos
Since you did not post your code, it's impossible to say exactly what the difference might be. You obviously created a different enum.
The simplest way to create the cluster is to simply right click on the input of the VI and select 'Create Control'. You would have automatically created a cluster of the correct type.
(2,952 Views)
Great!  I'll try it out.  Thanks
(2,946 Views)
