34970A channel delay
I am trying to set up a 3 second channel delay in the HP34970A Advanced Scan Example.vi.
I am measuring ac voltage and the scan occurs to quickly.
I have attached a screen shot.
When I run it, I get an error on the Agilent. ERR-222 Data Out of Range.
I assumed that the input was 3000 = 3 seconds and that I needed to place a False Value on the Auto Delay connection.
Can anyone tell what I did wrong?
(3,324 Views)
There is a similar forum post with an example VI attached.
http://forums.ni.com/ni/board/message?board.id=170&message.id=359083&requireLogin=False
Juan Galindo
(3,293 Views)
Problem solved. Thanks for your help.
I needed to increase the timeout value. 8 channels delayed 3 seconds is 24 seconds, I set the value to 26 seconds.
(3,274 Views)
